Community Member
Closing Telnet Port
I need to know how to close the telnet port in my router. Thanks.
Community Member
Re: Closing Telnet Port
Here is a link describing the transport input command as well as other ways to secure your router.
http://www.cisco.com/warp/public/707/21.html#general
Hope this helps...
configure "login" and "no password" under line vty 0 4
eg;
line vty 0 4
login
no password
R/Yusuf
Community Member
Yes you can do that also, but if someone port scans you, port 23 still will show as being open. To disable that port from showing up in port scans, you enter the command “transport input none” in your line vty 0 4 config.
Just good information to know…..
227
