CM_IKE_RECEIVED_DELETE_NOTIFICATION
Many IPSEC VPN clients 3.6.x suddenly cannot connect from different ISP to the VPN gateway and the below error shown. After few hours without any change in both sides, the problem solved automatically. Is it the VPN gateway problem or network problem?
GI VPNstart callback failed "CM_IKE_RECEIVED_DELETE_NOTIFICATION"
1 REPLY
Re: CM_IKE_RECEIVED_DELETE_NOTIFICATION
Do you have the logs from the VPN Server when the users experienced connectivity issues. If the 3.6.x clients were working before and then had issues connecting to the VPN Server, I would look at the logs on the VPN Server to see if we can identify anything that could have caused this issue.
Also, make sure that your pool of addresses is sufficient enough for all users connecting to the VPN Server.
Arul
** Please rate all helpful posts **
124
