09-14-2005 03:26 AM - edited 03-09-2019 12:25 PM
I am using pix firewall 501 6.3.4
Can anyone show me the command to open the following port in my pix firewall.
SIP: Port 5060 UDP
RTP: Port 8000 UDP
RTP: Ports 16384 to 20384 UDP
09-14-2005 04:10 AM
to explicitly open ports you should use access-list and access-group commands but maybe your problem solve by the fixup protocol so pls see the below link :
http://www.ciscopress.com/articles/article.asp?p=24685&seqNum=3&rl=1
09-14-2005 04:58 AM
Firstly thanks for reply
Can you please write down the command to open the port. I dont want to touch my current pix config until i knows the accurate command my network may goes down.
09-14-2005 06:09 AM
it doesn't recommend but if you have to open thoes ports from outside to inside :
access-list acl_out permit udp any any range 16384 20384
access-list acl_out permit udp any any eq 5060
access-list acl_out permit udp any any eq 8000
access-group acl_out in interface outside
please note if a access-group is applied to your outside interface, append above access lists to exist access lists.
if you can pls specify source/destination address or both of them in above access lists.
for more information about those commands :
09-14-2005 06:55 AM
Thanks for your reply.
See i will explain you why i want to open the port.
I would like to test the voip service through broadvoice they asked me to follow these steps http://www.broadvoice.com/support_install_byod_cis79xx.html
I am using cisco 7940 IP phone. I am not getting registered to the voip provider. They asked to to open the ports as because ip phone is behind firewall.
Here is no current Pix Firewall Config
Melbourne(config)# sh run
: Saved
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx encrypted
passwd xxxx encrypted
hostname Melbourne
domain-name Lex.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
object-group service UDPList udp
port-object eq 5060
port-object eq 8000
port-object range 16384 20384
access-list 101 permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inbound permit udp any host 203.49.XXX.XXX object-group UDPList
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside 192.168.0.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 101
nat (inside) 1 192.168.0.0 255.255.255.0 0 0
access-group inbound in interface outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set SecuritySet esp-des esp-sha-hmac
crypto map rtpmap 1 ipsec-isakmp
crypto map rtpmap 1 match address 101
crypto map rtpmap 1 set transform-set SecuritySet
crypto map rtpmap 1 set security-association lifetime seconds 3600 kilobytes 460
8000
crypto map rtpmap interface outside
isakmp enable outside
isakmp key ******** address 61.17.XXX.XXX netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash sha
isakmp policy 1 group 1
isakmp policy 1 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group Internet request dialout pppoe
vpdn group Internet localname lex@dodo.com.au
vpdn group Internet ppp authentication chap
vpdn username lex@dodo.com.au password *********
vpdn enable inside
terminal width 80
Cryptochecksum:xxxx
: end
Melbourne(config)#
Any Suggestion please so that i can use the voip service through cisco IP Phones.
09-14-2005 09:50 AM
you're using invalid ip address for your ip phone so did you enable nat on the 7940? do you obtain public ip address through pppoe? or you nat again at your service provider
09-14-2005 03:08 PM
I am using static IP which is provided by ISP. 203.49..xxx.xxx
DHCP is enabled on 7940. I have entered VOIP provider TFTP server in 7940.
Yes i obtain Public IP through PPPOE an you can see in my pix configuration.
09-14-2005 06:23 AM
As a side note, you should make sure protocol fixup for SIP is confugured also.
09-14-2005 03:07 PM
