Communication between remote VPNs
I have a VPN 3000 on the corporate site and clients in remotes offices behind VPN 3002 devices. Up until now all traffic has been between the remote sites and the corporate site and it has worked fine. I just ran into a need to communicate between the sites (specifically AVVID VOIP phones). I don't see where the routing problem is, but I'm sure it is there because the remote site cannot communicate with each other. Is there a setting on the 3000 that I'm overlooking that allows VPN endpoints to communicate with each other?
- Jim
Re: Communication between remote VPNs
Just make sure that the Split tunnel list if any thats being sent down to the CVPN3002, that should include the addresses for the newly added site aswell. Kindly make sure of that and see if that helps.
Aamir Waheed,
Cisco Systems, Inc.
Thanks!
That seems to have been the root of my problem. A little tricky in there, but finally got it working.
- Jim
84
