communication between vpn users and lan not working
ciscoasa(config)# sh run
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password xxx
names
interface Ethernet0/0
nameif outside
security-level 0
ip address ext_ip 255.255.255.240
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.17.193.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
clock timezone mst -6
access-list split_tunnel_list standard permit 172.17.193.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
ip local pool vpnuserspool 192.168.10.101-192.168.10.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 172.17.193.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 gw_ip
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 172.17.193.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
crypto dynamic-map dyn1 1 set transform-set FirstSet
crypto dynamic-map dyn1 1 set reverse-route
crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
no crypto isakmp nat-traversal
telnet timeout 5
ssh 172.17.193.0 255.255.255.0 inside
ssh timeout 60
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
dhcpd address 172.17.193.101-172.17.193.254 inside
dhcpd dns dns_1_ip dns_2_ip interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
ntp server 67.212.67.78 source outside
group-policy vpnuserspolicy internal
group-policy vpnuserspolicy attributes
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel_list
address-pools value vpnuserspool
username admin password xxx encrypted privilege 15
username admin attributes
vpn-group-policy vpnuserspolicy
tunnel-group vpnusersgroup type remote-access
tunnel-group vpnusersgroup ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:xxx
: end
ciscoasa(config)#
Re: communication between vpn users and lan not working
I want to enable VPN users to access resources on the LAN and vice versa. I did this:
access-list inside_nat0_outbound extended permit ip 172.17.193.0 255.255.255.0 192.168.10.0 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
Doesn't work. Any ideas?
Green
add...
perfect! thanks!
101
