Concentrator 3005 slow
I have a concentrator 3005 that I connect with the vpn client 4.1. The problem im having that might be normal is it runs slow. When I connect from home using a high speed connection file transfer from internal servers is very slow.Is there any thing I can do about this or look at.
  • Other Security Subjects
1 REPLY
Silver
Re: Concentrator 3005 slow
I have not worked on 3005 (I have 3015), but if you can look into the monitoring statistics like CPU usage, throughput, active sessions on the concentrator, it will give you a clue on why the concentrator is running slow. It could already be running at peak load.
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/admonbk/sysstat.htm
If you would like to have some dedicated bandwidth for your sessions, you can configure "Bandwidth policies"
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/config/polmgt.htm#1504094
125
