Concentrator Web Admin Locked
The web interface of my admin locked up just a litle bit ago. I was working on TFTP'ing some files and the admin stopped working. Right now I think connected users are okay, but I cannot start the admin or connect using the WebVPN. Any ideas? Thanks for your help, Don
Re: Concentrator Web Admin Locked
Don,
You'll probably have to wait for the system to either time out or you can go in through the console and disable and reenable the http web login.
From the main menu through console slect the following command:
Step1 --> 1) Configuration
Step2 --> 4) Management Protocols (Telnet, TFTP, FTP,etc.)
Step3 --> 2) Configure HTTP
Step4 --> 1) Enable/Disable HTTP
Patrick
Thank you for your reply! I tried the steps you laid out for me and, unfortunately, it didn't work. If you have any other ideas, I would apreciate it.
Thanks again,
Don
Don,
Sorry The only other option I can think of is to reboot the Concentrator maybe someone else might have soemthing for you.
Patrick
Thanks Patrick!
I wasn't sure what else to do either, so I had a chance to reboot this weekend and did - the web interface is back!
I appreciate your help! -Don
119
