conduit permit will not work in version 6.2
I just installed a new firewall pix520 with version 6.2 from a pix classic running 5.3. The following command will not work in 6.2 and I can't find any combination except using /32 bit mask.
"conduit permit tcp host 65.196.215.17 eq 22 66.7.64.97 255.255.255.248"
This fails with:
"ERROR: Source address,mask <66.7.64.97,255.255.255.248> doesn't pair"
Re: conduit permit will not work in version 6.2
Try 66.7.64.96. I believe that's the network address for .97-.102.
Yes, that is true. My question was whay won't the above mentioned command work in the new version of software.
I figured this out. In verion 6.2(2) you have to use the network address for a range. I had to use 66.7.64.96.
122
