Conduit statement and PDM
I am running PIX OS 5.2(3) and I am using conduit command not the ACL,
If I upgrade PIX to 6.1.2 and Install PDM 1.1.2 and use PDM to configure PIX in future, Is PDM will use conduit or ACL? Do I need to convert conduit statment to Access control list statement?
Please advise how old conduit statement and PDM work togather.
Is any one used conduit and PDM togather?
Thanks in advance.
Re: Conduit statement and PDM
PDM uses ACL, you need to convert conduits to ACL, they are opposite, conduits have destination and then source unlike the ACL, which has source and then destination.
R/Yusuf
Is there any utility to convert all conduit statement to ACL?
Do i have to convert static and nat statement also?
How have more than 200 statement, If there is utility it will make job easier.
Jayesh
It seems a bit odd theres no conversion utility.
I used cut/paste/edit/ and a bit of excel. This works ok and gives you an excuse to review your policies!
/dave
168
