Config L2TP VPN Clients along with IPSec Clients and Site-2-Site
Is it possible for the PIX to handle L2TP, Cisco VPN Client, and Site2Site IPSec configurations all with pre-shared keys? If so, where might I find a config example.
We currently have a home to branch office site2site IPSec tunnel, along with Cisco IPSec VPN Clients setup. I'd like to add the ablity for clients to connect with a pre-shared key via L2TP (e.g. via a mobile device such as WM5).
Thoughts? Suggestions?
  • Other Security Subjects
Gold
Re: Config L2TP VPN Clients along with IPSec Clients and Site-2-
Jeff,
Does the follwing link help....
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080093f89.shtml
Also, here's a very good document from Zander Networks on how to setup L2TP on Cisco PIX.
http://www.zandernetworks.co.uk/technotes/Tech%20Note%2004.pdf
Please remeber to rate post if it helps,
I actually already have a copy of the docs above.
After further thought, this has more to do with whether a single transform set can handle tunnel and transport mode.
Or rather, how does one setup transport mode for L2TP, when Cisco VPN Clients and Site2Site VPNs terminate on the same interface.
I figured it out. Multiple transform sets with the dynamic-map command.
crypto dynamic-map dynmap 40 set transform-set [trans#1] [trans#2]
256
