Community Member
Config Problem
Trying to import a profile and am receiving an error 22 "unable to import connection Entry. I have uninstalled and reinstalled already and that was no help. Any suggestions would be great
Silver
Re: Config Problem
Make sure you reboot after installing VPN If you have the profiles on a PC or a disk, just copy them into the following directory:
/etc/CiscoSystemsVPNClient/Profiles/ . No need to import them
Community Member
Re: Config Problem
Try restarting the service.
Highlighted
Community Member
Config Problem
Although this is a 5 year old post, I would like to add  comment
This problem can occur if the path to the pcf file contains characters from a language that is not supported by your local.
This happened with me because my locale is Arabic and the file path had a Danish letter
6328
