Community Member
Config required for DMVPN with HSRP in PLACE
Dear All,
I am now working In a setup below
Central Site
2-7206VXR routers for Redundancy.connectivity as follows
2-7206 each have redundancy to 2-6506 switch and these two switches have
redundancy to 2 WAN routers. simply the setup is as follows.
7206 \/ 6506 \/ Wan ROUTer----ISP
7206 /\ 6506 /\ Wan Router----ISP
Spoke site
more than 500 sites through MPLS it is connecting to HUB ( 1841 routers)
All spoke location routers are ipsec enabled IOS
My requriement
I am in need of configuring DMVPN in the central site so that there is no
need for me to add any configuration in the central site if any new spoke locations
comes up.I have gone through many documents in the cisco site for the same and i have configured the same.
But for my surprise nothing is working ( i.e the packets are not getting encrypted
and so on......) and how to sync the HSRP and ipsec.
I am not confident which ip must
Sample IP configuration
HSRP ip for 7206VXR is
Wan router ip ( as of now one WAN router is active )
I need configuration for both central site and the branches ( i.e it is tested in the live environment
and it is working fine).I am not sure that what must be the ip address
to give in the isamkmp key exchange ( i.e whether WAN or 7206 router's ) in Spoke locations.
I am running short of time, help me if you can
Re: Config required for DMVPN with HSRP in PLACE
DMVPN and HSRP are not designed to work together. When using pure IPsec with two hubs where you need redundancy, you have to combine this with a mechanism like HSRP. This is because we cannot run a dynamic routing protocol through the pure IPsec tunnels to help out with forwarding traffic. So the Stateful IPsec feature was added to specifically have IPsec work with HSRP and keep the IPsec and ISAKMP SA databases synchronized between the two HSRP routers. Therefore HSRP can switch the encrypted traffic between the two HSRP routers as necessary without too much loss of traffic.
DMVPN uses an active/active redundancy model where we build at least two spoke-hub tunnels one to each DMVPN hub from the DMVPN spoke. These tunnels come up immediately and stay up all of the time. With the DMVPN active/active redundancy model we didn't need Stateful IPsec nor a protocol to transfer NHRP mapping information between hub routers, since the hub routers would have their own independent IPsec and NHRP database information. Because of this DMVPN is not designed to work with HSRP.
