Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
config syntax and instruction execution order
conf t
service virtual-sensor-configuration virtualSensor
tune-micro-engines
systemVariables
FragmentReassembly
IPReassembleTimeout nnn
MaxPartialDatagrams nnn
MaxFragmentsPerDgram nnn
ReassembleMaxFragments nnn
exit
StreamReassembly
TCP3WayHandshakeRequired ''
TCPReassemblyMode ''
TCPOpenEstablishedTimeout nnn
TCPEmbryonicTimeout nnn
exit
exit
exit
Doing this out of memory, and am having some difficulty in remembering syntax and instruction execution order. I want to modify the variables above through the cli, in one shot. I get an err at MaxPartialDatagrams nnn.
Is the syntax and the order of instruction execution correct? Could someone step through the above and let me know?
1 REPLY
Re: config syntax and instruction execution order
It should be possible to make and apply a group
of cli commands in one shot. But there are
numerous syntax errors in your example.
Try making the changes manually, and then
combining those cli commands into a cli script.
For example, systemVariables is a mode command,
and should either be completed and exited or
removed from the script. MaxPartialDatagrams
and MaxFragmentsPerDgram are not configurable
elements. ReassembleMaxFragments should be
IPReassembleMaxFrags. TCP3WayHandshakeRequired
and TCPReassemblyMode do not take '' as param
values. The last exit should be replaced by yes.
92
