Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Configuration>Sensing Engine>Data Sources
What's the purpose of this feature?
I would like to know the way to limit the ip address that may trigger an alarm. My IDS is scanning a network where there are a lot of hosts and I only want to detect certain attacks (let's say those ones belonging to 192.168.1.0/24 but not 192.168.2.0/24)
Re: Configuration>Sensing Engine>Data Sources
From what you've written I'm guessing you want to use: Configuration>Sensing Engine>Filtered Signatures
As an example you could enter in the destination of 192.168.1.0/24 and put in asterisks for every other field (source, sig, sub-sig).
Is this what you're after?
Just so you know the Data Sources, are the ip addresses of Cisco Routers that are sending syslog messages to the sensor. The sensor can then generate alarms from the syslog messages when ACL denials ocurr. The alarm generated is the 10000 Policy Violation alarm.
Most users do not use this feature, and it will not help in what you are trying to accomplish. The method described by seba is the method to use.
That's right
Thank you very much
98
