configuration question
on vpn on the router with ipsec and 3 dec what do i have to do in the configuration so i don't have to us lmhosts files for each computer.
please let me know.
thanks
1 REPLY
Re: configuration question
lmhost file on the PC is used for WINS resolution. If you do not want to use them, then you must provide a WINS server IP address to this PC so whenever it needs to resolve names, it points to this WINS server instead of local lmhost file.
Now the question is, how do you assign your PC an IP address
- statically ??
- dynamically usign a DHCP server
- dynamically from the router pool
whichever method you use, you can assign the WINS/DNS server to all the clients.
If the clients are obtaining the IP from the router pool, then you can add following additional command(s) to assign WINS/DNS server;
async-bootp nbns-server x.x.x.x (for WINS)
async-bootp dns-server x.x.x.x (for DNS)
R/Yusuf
82
