Configuring 3des between at 2610 and 2621 router
I am using IOS c2600-ik2s-mz.121-16.bin on both routers but can not get the command show crypto isakmp sa to show the connection
**********Config 1********************
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname router1
memory-size iomem 10
ip subnet-zero
crypto isakmp policy 1
authentication pre-share
crypto isakmp key test address 192.168.10.66
crypto ipsec transform-set test esp-des
crypto map test 10 ipsec-isakmp
set peer 192.168.10.66
set transform-set test
match address 101
interface Ethernet0/0
ip address 192.168.3.1 255.255.255.0
crypto map test
interface Serial0/0
ip address 192.168.10.38 255.255.255.0
no fair-queue
clockrate 56000
crypto map test
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.66
ip http server
access-list 101 permit ip 192.168.3.0 0.0.0.255 10.3.2.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
end
****************Config 2*************************
version 12.1
hostname router2
ip subnet-zero
crypto isakmp key test address 192.168.10.38
set peer 192.168.10.38
match address 101
controller T1 1/0
interface FastEthernet0/0
ip address 10.3.2.1 255.255.255.0
duplex auto
speed auto
crypto map test
interface Serial0/0
ip address 192.168.10.66 255.255.255.0
no fair-queue
crypto map test
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.38
ip http server
access-list 101 permit ip 10.3.2.0 0.0.0.255 192.168.3.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
end
Re: Configuring 3des between at 2610 and 2621 router
On both routers, why do you have a "crypto map test" under the inside/lan interface (e0/0 and f0/0)? Remove them so only the outbound interface has the crypto map statement.
Steve
Had those in there for testing. I ended up having the config correctly all along just wasn't testing right.
Thanks for the help.
146
