configuring 501 behind 801 ISDN-dailup
hi,
I have the following config for my 801 ISDN (dialup). what would be my basic config for PIX 501 ?
hostname xxxxx
enable secret 5 XXXXX
username xxxxx password XXXXX
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface Ethernet0
ip address 192.168.0.241 255.255.255.0
ip nat inside
no ip route-cache
no cdp enable
interface BRI0
Description connected to the internet
no ip address
ip nat outside
encapsulation ppp
no ip route-cache
dialer pool-member 1
no cdp enable
interface Dialer1
description CONNECTION TO INTERNET
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache
no ip split-horizon
load-interval 30
dialer pool 1
dialer idle-timeout 300
dialer string xxxxxx
dialer hold-queue 10
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxxxx password xxxxxx
ip classless
no ip http server
no cdp run
line con 0
login
stopbits 1
line vty 0 4
password cisco
login
no rcapi server
end
I have also not added any route, on the router, i think it has to be on the pix, any help on basic pix config is appreciated
thanks & regards
sk
Re: configuring 501 behind 801 ISDN-dailup
Read the following URL for details on basic configuration of PIX firewall,
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a00800eb0b0.html
Hello Everybody!
This is my routeur config:
ciradvxh#sho startup-config
Using 1953 out of 8046 bytes, uncompressed size = 3548 bytes
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname ciradvxh
boot system flash aaa0842.bin
no logging console
enable secret xxxxxxx
enable password xxx
username IPSGUAD password xxxxxxxxx!
ip subnet-zero
no ip source-route
ip inspect name fwr ftp
ip inspect name fwr h323
ip inspect name fwr realaudio
ip inspect name fwr smtp
ip inspect name fwr sqlnet
ip inspect name fwr streamworks
ip inspect name fwr tcp
ip inspect name fwr udp
no ip domain-lookup
no ip finger
isdn switch-type vn3
isdn tei-negotiation first-call
process-max-time 200
interface Ethernet0
description lan Cirad Vx Habitants
ip address 192.168.0.254 255.255.255.0
ip access-group 121 in
ip access-group 122 out
no ip directed-broadcast
ip nat inside
ip inspect fwr in
no cdp enable
interface BRI0
description Liaison NUMERIS
no ip address
encapsulation ppp
dialer pool-member 2
dialer pool-member 3
isdn send-alerting
no cdp enable
interface Dialer1
description MEDIASERV
ip access-group 123 out
ip nat outside
ip inspect fwr out
encapsulation ppp
no ip route-cache
no ip split-horizon
dialer remote-name REGGAE
dialer idle-timeout 90
dialer string 00590326464
dialer caller 00590326464
dialer hold-queue 30
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username ciradvxh password 7 xxxxx
interface Dialer2
description connx SAV
ip address x.x.x 255.255.0.0
encapsulation ppp
no ip split-horizon
dialer remote-name IPSGUAD
dialer string 00590894500
dialer caller 00596894500
dialer pool 2
dialer-group 2
no cdp enable
ppp authentication chap
interface Dialer3
description Neufchateau
ip nat outside
encapsulation ppp
no ip route-cache
no ip split-horizon
dialer remote-name hpglp
dialer string 00590861785
dialer caller 00590861785
dialer pool 3
dialer-group 3
ppp authentication pap chap
ppp pap sent-username pfo-vxh password xxx;
ip nat inside source list 121 interface Dialer1 overload
no ip http server
ip classless
no ip forward-protocol udp tftp
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 11.17.0.0 255.255.0.0 Dialer2
ip route 97.142.0.0 255.255.0.0 Dialer2
ip route 212.155.143.0 255.255.255.0 Dialer1
ip route 213.188.0.0 255.255.0.0 Dialer1
access-list 121 permit ip any any log
access-list 121 permit ip 192.168.0.0 0.0.255.255 any log
access-list 121 deny ip any any log
access-list 122 permit ip any any log
access-list 122 permit ip 97.142.1.0 0.0.0.255 any log
access-list 122 permit icmp any any log
access-list 122 deny ip any any log
access-list 123 permit ip any any log
access-list 123 deny udp any any eq netbios-ns
access-list 123 deny udp any any eq netbios-dgm
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
dialer-list 3 protocol ip permit
line con 0
exec-timeout 0 0
transport input none
stopbits 1
line vty 0 4
exec-timeout 60 0
password xxxx
login
end
We recently added a server gateaway. Our ISDN line automaticaly connects and i don't understand why! It was the same before we buy the server.
In French system, you pay each time it connects so, it's a problem for us. Can you help us please to understand what happend in this traffic. btw: i've got a routeur cisco 803, but the debug command only give me messages like this: Dial on demand packets/events debugging is on! So i can't know who connects and when!
Thanks for your cooperation.
You need to configure inside ip with mask of your network, then an outside ip, and a default route to the lan adress of your ISDN router. You also need to change the ethernet ip, of ISDN router to another network. Search the Cisco technical document for config example. Good luck!
//Patrik.
102
