07-05-2006 11:45 AM - edited 02-21-2020 10:16 AM
Has anyone configured their stand alone (non-Cisco Works 2k bundled) CSA 5.1 installations to use LDAP authentication to their Active Directory? I've been fumbling around with parameters and haven't had any success.
LDAP Configuration
Server: ldap://<serverIP>
Usersroot: dc=
Prefix: uid=
That is the unconfigured, default values in the Login Configuration option. The in-line help doesn't provide much information on getting this up and running. Do I need comma separated values for the "Prefix", such as "cn=users,dc=corp,dc=company,dc=com", etc.?
Please advise.
07-11-2006 10:58 AM
Administrator LDAP authentication is explained here;
07-11-2006 12:26 PM
I appreciate your response, however, that information is the same as the in-line help, which I've read and found not to provide the information I'm looking for. Thanks.
07-13-2006 08:00 PM
Here's a sample of the configuration line running in one of my pilot servers:
Server:
ldap://ldap.csalab.com
Usersroot:
ou=active,ou=employees,ou=people,o=csalab.com
Prefix:
uid=
09-12-2006 03:55 AM
Do you put anything in the uid field?
09-12-2006 05:56 AM
If you're using Active Directory, and your domain looks like "yourdomain.local", then it should be like this:
LDAP Configuration:
Server: ldap://10.1.2.33
Usersroot: dc=yourdomain,dc=local
Prefix: cn=Administrator
And look at the note at the bottom - "Note: A local admin account matching the LDAP login name is mandatory for defining the administrator priveleges". I think this means if your AD admin account is "Administrator", then the mc needs an account called "Administrator" as well - but it doesn't require a local password because it will authenticate against AD.
I wish I could test this out for you, but I'm not running 5.1 yet.
