Configuring DMVPN
I have a 2821 cisco router with several site to site vpns configured.
I want to configure this router like a primary HUB for DMVPN....if I configure this router like a primary hub, configured site to site vpn will not work or will work untill I swich from von site from site to site to dmvpn?
Best regards
Bronze
Re: Configuring DMVPN
You can use a router as hub for DMVPN and also for site to site vpn connections. Take care of the point to use a new isakmp policy, there will be no need of a new transform set.
Ummm
I tried to configure dmvpn using the wizard but too much parameters...
My lan is 192.168.156.x and remote lans 157.x 155.x and more.
The 2821 router is connectec using gigabit ether0/1 with ip 83.x.x.x.
Then, how can I configure the first hub? and the the remote spokes?
best regards and thks
305
