Community Member
Configuring IPSEC between two routers Cisco 827 and Cisco VPN client 3.x
I want to connect two site via Ipsec and permit It connections with cisco vpn client 3.x for my remote acces users via Internet.
This is the configuration but I think that it isn´t correct. The conections with the cisco vpn client it is ok but site to site it is the problem.
Any idea ???
The configurations routers:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ADSLBILBAO
enable secret 5 $1$LKYB$iqp2TI4poW72DlscNbHKc0
enable password 7 0216160F5E000A731F
username COMAcceso password 7 0233337E3D23377019
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
class-map match-all voice
match none
policy-map POLICY
class voice
priority 480
crypto isakmp policy 1
hash md5
authentication pre-share
crypto isakmp key cisco123 address 212.145.203.130
crypto ipsec transform-set vpn-transform esp-3des esp-md5-hmac
crypto map rasvpn 1 ipsec-isakmp
set peer 212.145.203.130
set transform-set vpn-transform
match address 107
interface Loopback0
no ip address
interface Ethernet0
ip address 192.168.145.1 255.255.255.0
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
mtu 300
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/33
vbr-rt 640 640 10
encapsulation aal5mux ppp dialer
dialer pool-member 1
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
shutdown
dialer pool 1
ppp authentication chap
ppp chap hostname xxxxxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxxxxxxxx
crypto map rasvpn
ip nat inside source route-map nonat interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip pim bidir-enable
access-list 101 deny ip 192.168.145.0 0.0.0.255 192.168.143.0 0.0.0.255
access-list 101 deny ip 192.168.145.0 0.0.0.255 192.168.146.0 0.0.0.255
access-list 101 permit ip 192.168.145.0 0.0.0.255 any
access-list 107 permit ip 192.168.145.0 0.0.0.255 192.168.143.0 0.0.0.255 preced
ence critical
access-list 107 permit ip 192.168.145.0 0.0.0.255 192.168.146.0 0.0.0.255 preced
ence critical
route-map nonat permit 1
match ip address 101
line con 0
stopbits 1
line vty 0 4
password 7 1352431A0D555C212C2C
login
scheduler max-task-time 5000
end
Another router:
Current configuration : 3122 bytes
version 12.2
no service pad
hostname CISCOADSL
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
enable secret 5 $1$7v25$iZXmJqMoRMIknHTkna4ms0
enable password 7 1545531A13797E25
username COMAcceso password 7 110210314234060251
username voiceware password 7 14011D020F013D2A362D
no mmi pvc
ip subnet-zero
crypto isakmp policy 3
encr 3des
hash md5
group 2
crypto isakmp policy 10
hash md5
crypto isakmp key cisco123 address 212.145.206.254
crypto isakmp client configuration group rasvpn
key cisco123
dns 192.168.143.70
wins 192.168.143.64
domain voiceware.net
pool ippool
crypto ipsec transform-set rasvpn-transform esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set rasvpn-transform
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap client configuration address respond
crypto map clientmap 1 ipsec-isakmp
set peer 212.145.206.254
match address 107
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
interface Loopback0
no ip address
interface Ethernet0
ip address 192.168.143.5 255.255.255.0
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
pvc 0/33
bundle-enable
hold-queue 224 in
interface Dialer0
ip nat outside
encapsulation ppp
no ip route-cache
no ip mroute-cache
shutdown
dialer pool 1
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxx
ppp chap password xxxxxxxxxxxxxxxxxxxxxxxxxx
ip local pool ippool 192.168.147.1 192.168.147.254
ip nat inside source static tcp 192.168.143.65 1352 212.145.203.130 1352 extenda
ble
ip nat inside source static tcp 192.168.143.70 25 212.145.203.130 25 extendable
ip nat inside source static tcp 192.168.143.70 80 212.145.203.130 80 extendable
ip nat inside source static tcp 192.168.143.70 110 212.145.203.130 110 extendabl
e
ip classless
no ip http server
ip pim bidir-enable
access-list 101 deny ip 192.168.143.0 0.0.0.255 192.168.0.0 0.0.255.255
access-list 101 permit ip 192.168.143.0 0.0.0.255 any
access-list 107 permit ip 192.168.143.0 0.0.0.255 192.168.146.0 0.0.0.255
access-list 109 permit ip 192.168.143.0 0.0.0.255 192.168.145.0 0.0.0.255
access-list 109 permit ip 192.168.146.0 0.0.0.255 192.168.145.0 0.0.0.255
line con 0
stopbits 1
line vty 0 4
end
CISCOADSL#
Re: Configuring IPSEC between two routers Cisco 827 and Cisco VP
The only issue I can see so far is that you have statics on the second router config, which the peer network won't reach because of the nat and the route map policy you use.
I would think the with the config, the inside interface of the routers, should be able to ping each other by extended ping. If you want the first router network to reach the host with the static on the 2nd network, you need to do something like this for you nat : http://www.cisco.com/warp/public/707/static.html .
Otherwise, you might want to consider opening a case with the tac.
Community Member
Thanks for the answer but I kwon that you say referent with static but my really problem it is the tunnel between the two router it is´nt operational and I dont kwon the reason.
Thanks, regards
besides having the crypto on dialer, also apply it on the physical interface, atm.
If you still have issues, please open a case with tac.
Community Member
Besides the fact that your dialer is shutdown on both routers? With out seeing the debugs, id take a guess that CISCOADSL router is probably prompting the other router for username/password. Debugs would be more helpful though to determine that. Debug crypto ipsec and debug crypto iskamp. If thats the case you need to change your preshared key for your peer from crypto isakmp key cisco123 address 212.145.206.254 to crypto isakmp key cisco123 address 212.145.206.254 no-xauth. If your still getting problems, remove the aaa from the router, if you have too remove the client config. That should tell you where your config issue is at.
Kurtis Durrett
Community Member
Hi everybody,
I had the same problem and this the config that worked for me.
It's a little bit redundant but from my personel experience it make things
easier to follow.
My example does include 3 private networks but no single vpn-client,
because this is one thing i did not jet realize.
TOPOLOGY:
The hosts are connected through non NATed IP-SEC tunnels,
other internet access is NATed as usual.
LAN1
host1
/ INET \
host2 -------- -host3
LAN2 LAN3
host1
version 12.2
hostname host1
ip domain-name mydomain.name
! These are the rules for statefull inspection firewall
ip inspect max-incomplete high 1100
ip inspect max-incomplete low 900
ip inspect one-minute high 1100
ip inspect one-minute low 900
ip inspect name FastEthernet_0 realaudio
ip inspect name FastEthernet_0 ftp
ip inspect name FastEthernet_0 udp
ip inspect name FastEthernet_0 tcp
ip inspect name FastEthernet_0 sqlnet
crypto isakmp enable
crypto isakmp identity address
! This defines policies for the authentification of packets between the
! VPN-routers. Both routers must agree on one policy, so you need to have
! at least one matching policy on each router or they will not connect.
! I decided on a single policy for all connections, which becommes mandatory
! that way. The used preshared keys are then defined next.
encr 3des
! Preshared-Key router1 to router2
crypto isakmp key key4conn_1_2 address 220.220.220.1 no-xauth
! Preshared-Key router1 to router3
crypto isakmp key key4conn_1_3 address 230.230.230.1 no-xauth
! The Transform-Set is the policy for the encryption of packets between the
! VPN-routers. As above, both routers need to have a matching policy on each
! router or they will not connect. You may define more than one transform-set
! for different purposes, but you can use the same for many connections
! as well.
crypto ipsec transform-set tfs_3DES ah-sha-hmac esp-3des
! The Crypto-Map binds together the encryption policy with the IP-adress
! of the peer router and and the access-list (# 120 in this example)
! which defines wich packet are allowed to go to that peer
crypto map my-cr-map 1 ipsec-isakmp
set peer 220.220.220.1
set transform-set tfs_3DES
match address 120
! same as above for net 3 and access-list 130
crypto map my-cr-map 2 ipsec-isakmp
set peer 230.230.230.1
match address 130
! The INET Interface gets the crypto-map aplied and has a policy for
! incoming connections, which is defined in access-list 101
interface Ethernet0
description connected to Internet
ip address 210.210.210.1 255.255.255.252
ip access-group 101 in
ip nat outside
! LAN is allowed everything outgoing into the INET, on the way back things
! are inspected as defined in the IP INSPECT rules above
interface FastEthernet0
description connected to EthernetLAN
ip address 192.168.210.1 255.255.255.0
ip nat inside
ip inspect FastEthernet_0 in
router rip
version 2
passive-interface Ethernet0
network 192.168.210.0
no auto-summary
! This statement allows only those packets to be NATed which fit to
! the route-map with the name noNAT (this ist CaSe sensitive) defined
! at the end of this config file and the according rulset 110. Only it fit's
! to the rule the packet get the adress of the interface Ethernet0 applied.
ip nat inside source route-map noNAT interface Ethernet0 overload
! This is my providers DSL router, which receives all trafic to the INET
! which is not otherwise defined (this is the default route)
ip route 0.0.0.0 0.0.0.0 210.210.210.2
! This list allows incomming trafic from the INET. This is where I had the
! big problem to connect my networks. I only got it to work, when I turned the
! logic in these rules around, so against all other rules the local part of the
! entry is on the back and the incomming host is named first.
! Router of net 2 and the private net 2 are allowed all IP inbound
access-list 101 permit ip host 220.220.220.1 host 210.210.210.1
access-list 101 permit ip 192.168.220.0 0.0.0.255 192.168.210.0 0.0.0.255
! Router of net 3 and the private net 3 are allowed all IP inbound
access-list 101 permit ip host 230.230.230.1 host 210.210.210.1
access-list 101 permit ip 192.168.230.0 0.0.0.255 192.168.210.0 0.0.0.255
! This List denies NAT for connections to the 2 private networks which are
! connected through encrypted IPSEC-tunnel, so the private IPs are not seen
! outside, but only the real IP of the router, who is sending the encrypted
! packets. Any packets not sent to 192.168.220 or 192.168.230 are NATed and
! sent to the INET unencrypted.
! This list is used for the route-map statement following below.
access-list 110 deny ip 192.168.210.0 0.0.0.255 192.168.220.0 0.0.0.255
access-list 110 deny ip 192.168.210.0 0.0.0.255 192.168.230.0 0.0.0.255
access-list 110 permit ip 192.168.210.0 0.0.0.255 any
! This rule allows only packets to the private net 192.168.220.0 to become
! encrypted and then be sent in the tunnel to router 220.220.220.1, who
! decrypts them and passed them on to his local network again.
! This works together with the first crypto map statement above
access-list 120 permit ip 192.168.210.0 0.0.0.255 192.168.220.0 0.0.0.255
! Same as obove for the second net
! This works together with the second crypto map statement above
access-list 130 permit ip 192.168.210.0 0.0.0.255 192.168.230.0 0.0.0.255
! This route map deciedes, if a packet is NATed or not. If it is permited in
! rule 110, it gets NATed, if it's denied, then it stays as it is.
route-map noNAT permit 10
match ip address 110
host2
version 12.2
hostname host2
encr 3des
! Preshared-Key router2 to router1 and IP-adress of peer-router
crypto isakmp key key4conn_1_2 address 210.210.210.1 no-xauth
! Preshared-Key router2 to router3 and IP-adress of peer-router
crypto isakmp key key4conn_2_3 address 230.230.230.1 no-xauth
! as well.
set peer 210.210.210.1
match address 120
match address 130
interface Ethernet0
ip address 220.220.220.1 255.255.255.252
ip nat outside
ip address 192.168.220.1 255.255.255.0
ip nat inside
router rip
version 2
network 192.168.220.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 220.220.220.2
! Router of net 1 and the private net 1 are allowed all IP inbound
access-list 101 permit ip host 210.210.210.1 host 220.220.220.1
access-list 101 permit ip 192.168.210.0 0.0.0.255 192.168.220.0 0.0.0.255
access-list 101 permit ip host 230.230.230.1 host 220.220.220.1
access-list 101 permit ip 192.168.230.0 0.0.0.255 192.168.220.0 0.0.0.255
access-list 110 deny ip 192.168.220.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 110 deny ip 192.168.220.0 0.0.0.255 192.168.230.0 0.0.0.255
access-list 110 permit ip 192.168.220.0 0.0.0.255 any
! This rule allows only packets to the private net 192.168.210.0 to become
! encrypted and then be sent in the tunnel to router 220.220.210.1, who
access-list 120 permit ip 192.168.220.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 130 permit ip 192.168.220.0 0.0.0.255 192.168.230.0 0.0.0.255
host3
version 12.2
hostname Host3
encr 3des
! Preshared-Key router3 to router1
crypto isakmp key key4conn_1_3 address 210.210.210.1 no-xauth
! Preshared-Key router3 to router2
crypto isakmp key key4conn_2_3 address 220.220.220.1 no-xauth
! as well.
match address 120
! same as above for net 2 and access-list 130
match address 130
interface Ethernet0
ip address 230.230.230.1 255.255.255.252
ip nat outside
ip address 192.168.230.1 255.255.255.0
ip nat inside
router rip
version 2
network 192.168.230.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 230.230.230.2
access-list 101 permit ip host 210.210.210.1 host 230.230.230.1
access-list 101 permit ip 192.168.210.0 0.0.0.255 192.168.230.0 0.0.0.255
access-list 101 permit ip host 220.220.220.1 host 230.230.230.1
access-list 101 permit ip 192.168.220.0 0.0.0.255 192.168.230.0 0.0.0.255
! packets. Any packets not sent to 192.168.210 or 192.168.220 are NATed and
access-list 110 deny ip 192.168.230.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 110 deny ip 192.168.230.0 0.0.0.255 192.168.220.0 0.0.0.255
access-list 110 permit ip 192.168.230.0 0.0.0.255 any
access-list 120 permit ip 192.168.230.0 0.0.0.255 192.168.210.0 0.0.0.255
access-list 130 permit ip 192.168.230.0 0.0.0.255 192.168.220.0 0.0.0.255
Hope it helps,
Christoph Sonnen
220
