Community Member
configuring LAN to LAN on 3005 to establish tunnel with 0.0.0.0 (unknown)
Is there a way to establish a LAN-to-LAN tunnel with a device that is acquiring a dynamic outside address.
Scenerio:
827or501<-(DSLgetdynamicIP)->ISP<-------WWW--------->3000Concentrator
-An 827 router or PIX 501 at a remote office with only 3 users
-A 3005 concentrator at our main office (has a static Global IP on E0)
-the remote office device (827 or 501) connects the LAN to the Internet via DSL and acquires it's outside address via DHCP
-the VPN peer configured on the remote office device would be the outside interface of the 3000 concentrator at our main site
-the LAN-2-LAN peer configured on the 3000 will be 0.0.0.0
is it possible for a concentrator to establish a LAN-2-LAN with an unknown peer LAN, as long as the preshared keys match? I know this is a potential security risk, but is this setup possible?
-any help greatly appreciated-
e.l
Community Member
Re: configuring LAN to LAN on 3005 to establish tunnel with 0.0.
The above is possible.
Just configure the VPN3000 to accept a remote hardware client VPN connection from PIX501/827 and use "network extension mode". The following is sample configuration:
http://www.cisco.com/warp/public/471/pix501506_vpn3k.html
LAN-2-LAN tunnel from a VPN 3000 to IKE peer 0.0.0.0 cannot be configured.
Nelson
This is the sample configuration you have to follow:
http://www.cisco.com/warp/public/471/vpn3k_iosdhcp.html
101
