Configuring privilege issue
I need some advice here. I am trying to configure a router for access privileges.
Following is the configuration:-
enable secret level 14 5 $1$yQtt$0yL38AHKDnpuLO3MMaGi3/
privilege configure level 14 interface
privilege configure level 14 interface shutdown
privilege configure level 14 interface no shutdown
privilege configure level 14 interface ip address
privilege configure level 14 interface no ip address
privilege exec level 14 show run
privilege exec level 14 configure terminal
privilege exec level 14 show startup
Problem is that though user can login in access level 14 but he faces two issues:-
1. sh run output is appears only as
Building configuration...
Current configuration : 80 bytes
interface Tunnel0
interface FastEthernet0/0
interface Async5
end
But sh startup is completely shown with all the information.
2. User can enter interface config mode but if he tries to configure ip address or shutdown interface, it doesn't work.
Any help will be greatly appreciated.
--Noman Bari
Re: Configuring privilege issue
Hi Noman Bari
AFAIK all config related commands can be executed only from privilege level 15.
Even Show run in any other privilege level except level 15 will fetch you the above output only.
regds
Hi kumar,
Thanks for your response and helping out..while tweaking around my initial posting, i stumbled upon what worked for me and this works now..
--Noman Bari
102
