Community Member
configuring sh runn in lower priveldge??
I want to create a user who has the access to sh running config and extended ping but can not modify the config. How to do that? I have tried with 'priviledge exec level 10 more system:running-config' but after that in 'show runn' the output is blank.
Re: configuring sh runn in lower priveldge??
Is the user login in at the proper privilege level? If the command is set at level 10, then the user can login at priv level 10 by entering
enable 10
example:
enable password level 10 pswd10
privilege exec level 10 clear line
More info on this link;
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_c/fothersf/scfpass.htm#23545
Hope this helps.
Thanks.
yatin
Also, did you turn on AAA authorization? Try configuring the below on this router;
aaa new-model
aaa authentication login default group tacacs local
aaa authorization exec default group tacacs local
username abc privilege 2 password abc
username boss priv 15 password boss
privilege exec level 2 show running-config
More info on the 'sh runn' command issues;
http://www.cisco.com/warp/public/63/showrun.shtml
yatin
Community Member
After this router accepts sh runn command but shows nothing in configuration.
As per the following link it can not be done. Am I right?
http://www.cisco.com/en/US/tech/tk583/tk642/technologies_tech_note09186a00800949d5.shtml
Silver
Please refer to the following URL for work-around.
Mynul
138
