Configuring Zone Alarm to work with VPN Client 3000
How do I configure my Zone Alarm to allow the VPN Client 3000 to access the network? Currently the Zone Alarm does not allow the VPN Client to go out through my DSL connection.
As a note, I am using the IPsecdialer.
Thanks.
Brian
1 REPLY
Bronze
Re: Configuring Zone Alarm to work with VPN Client 3000
To connect a vpn tunnel through a firewall you will need to open udp port 500, if the traffic is being PATed (ipsec through NAT) you will need to open udp port 10000 as well, then allow protocol's ESP(50) an AH(51) through.
386
