Community Member
connect to remote other network using vpn client from behind corporate asa
Hi, I have successfully connected to a remote site using client from behind our asa, however we are unable to access any resouces over the tunnel. If we use same laptop, same config on an un firewalled cable modem connection, we are able to connect to the resources on the other side of the tunnel. Seems like it is the asa on the corp. network, but we do have a fat pipe appliance in front of the asa that may be the issue. We dont have any network overlap issues and I cant see any routing problems. Any thoughts?
Community Member
Re: connect to remote other network using vpn client from behind
I figured it out. Client issue.
Community Member
hi
post your ASA Config if u dont mind
regs
S.Mohanasundaram
130
