connection failures
Hello
I have a group of users that connect to tha PIX firewall (515e running 6.3) via PPTP (VPDN). These users receive an IP address on subnet 192.168.2.x. The same PIX as an IPSEC tunnel to another IPSEC peer. The network behind the other IPSEC VPN peer is 172.31.x.x. I'm trying to have the users that connect to the PIX via VPDN reach the network that is on the other side of the IPSEC tunnel. Is this possible?
TIA
Paolo
1 REPLY
Re: connection failures
Version 6.3 will not allow you to do IPSec hairpinning. You need to be at v7.x and above to achieve what you are trying to do.
Pradeep
220
