Connection through VPN to another network (PAT)
We have a PIX 525 that has an IPSEC VPN terminated on the outside interface. Clients use the Unified 3.5.1c.k9 client to connect with the PIX which they can do successfully and access resources on the inside interface.
We also need to access another companies network which is connected on a different PIX interface and all client connecting to this remote network use PAT. Is it possible for the VPN clients to connect to this other companies network and if so how do I configure it so. The PIX is running 6.2(1).
Thanks in advance.
1 REPLY
Re: Connection through VPN to another network (PAT)
Either your clients directly vpn to the other PIX, or if you say you have a connection to this remote via another interface of your current PIX, you could
form a lan2lan tunnel to this remote pix and tunnel your vpn client accordingly, as in:
http://www.cisco.com/warp/customer/110/client-pixhub.html
82
