Connection upgrade
I have a Pix 525 connected to the "internet" using the 100Mb ethernet interface named "Outside".
I need to upgrade that connection to a Gigabit connection using the GigabitEthernet fiber interface.
Is there a way of doing this without loosing all the configurations of the 100Mb interface? Like the nat and security rules.
Or do i have to disable the ethernet interface, enable the gigabit and rebuild all the configurations?
I didn't found any documentation about this problem.
Thanks for any help.
Regards.
Re: Connection upgrade
You can do it without loosing configuration.
Disabled ethernet0 (default outside with security level 0) and assign new GE as new outside interface.
1. Remove IP Address from old outside (e0) interface:
no ip address outside
2. Disable the e0 port
interface ethernet0 auto shutdown
2. Rename old outside intf (e0) to new name, and set new security level. Outside interface is recommended (default) to use 0.
nameif ethernet0 outside1 security1
3. Re-assign new GE as outside interface with security 0:
nameif gb-ethernet0 outside security0
4. Enable new GE interface
interface gb-ethernet0 1000auto (or fix the speed to 100full)
5. Assign ip address (inherited from old outside IP) to new GE/outside
ip address outside x.x.x.1 255.255.255.0
Leave everything like "Global (outside)" statement as it is, together with route, acl and so on.
I have configured PIX525 with 5 GE (fiber) ports, and put both default eo and e1 to disabled mode.
interface gb-ethernet1 1000auto
interface gb-ethernet2 1000full
interface gb-ethernet3 1000auto
interface gb-ethernet4 1000auto
interface ethernet1 auto shutdown
nameif gb-ethernet1 inside security100
nameif gb-ethernet2 statefover security80
nameif gb-ethernet3 dmz security70
nameif gb-ethernet4 vpn security50
nameif ethernet0 reserved1 security1
nameif ethernet1 reserved-2 security2
Pls backup your config before performing the above, and do not save (wri mem) the PIX until it's confirmed to be working fine. If something went wrong, just reboot the box and it's back to last-known-good config.
AK
Thanks for your help.
I was thinking in doing the changes offline and then upload the config file (tftp) and reboot the pix. The only thing that needs changing is the interface name, the ip of the new connection is the same.
I will try your solution.
I had to do the changes offline and then do the upload to the pix... doing the changes online didn't work.
96
