Connection VPN
Hello!
I must parameterize a router speedstream 5711 who is on the central site (150 PC, 10 switch Cisco, server 2000) and a router Cisco 800 on a site distant (20 PC, 2000 pro and 9 to integrate a connection VPN into it? and I will like to know how to make?
I am explained the two routers are already to install and to configure via a line specialized and I must thus parameterize these two routers to use connection VPN.
central site: Ethernet distant
site: Token Ring
thank you
1 REPLY
Silver
Re: Connection VPN
VPNs can be deployed using different methods.The following doc illustrates them and would tell you how to choose the right one.
http://www.cisco.com/warp/customer/707/which_vpn.html
The IPSec Suport page has a lot of information. You might be able to locate the right doc from this page based on the type of link that the VPN has to be configured on since that is not mentioned.
http://www.cisco.com/cgi-bin/Support/browse/psp_view.pl?p=Internetworking:IPSec&viewall=true
The documentation for 800 series can be found at:
http://www.cisco.com/warp/customer/cc/pd/rt/800/prodlit/index.shtml
82
