02-19-2004 08:49 AM - edited 02-20-2020 11:15 PM
We have a PIX running 6.2 and the connections don't timeout anymore. There are connections that are 180 and 190 hours old. Connections are UDP (DNS and non DNS) and TCP.
Probably there is a bug for this and I didn't see it.
Anyone saw that before or have the bug ID ?
A reboot clears the problem.
Ouajih
02-19-2004 08:52 AM
This is definitely a bug. I will serach the bug id for you, but you can safely upgrade to the latest code, since the bug has been fixed.
Nadeem
02-19-2004 08:55 AM
the bug id is CSCdy58717
Nadeem
02-19-2004 09:56 AM
Thanks a lot,
Best regards,
Ouajih
