Context question
Default is 2 on a PIX 515E, but can be maxed out at 5. How do you activate it to 5? I have UR license and 16mb flash with 128 meg of RAM. My activation key was for 7.0(1) and has 5 tuples in the key.
1 REPLY
Re: Context question
Assuming your PIX515E is loaded with ASA 7.0(1), activate the 5 security context license using "activation-key" command.
hostname(config)# activation-key
*replaced the with your 5-element hex string with one space between each element
Example:
hostname(config)# activation-key 0xe02888da 0x4ba7bed6 0xf1c123ae 0xffd8624e 0x3a8da7be
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080450b92.html#wp1048072
AK
101
