09-18-2003 04:51 AM - edited 02-20-2020 10:59 PM
I'm trying to get statistics for CPU usage and connections through SNMP. I did it on my lab pix 515e 6.2 and it works. After
this I did it on the second pix 515 6.0(1) and as you can see on the output it doesn't work only for CPU. Is it any bug at
6.0(1) software that I can't get CPU usage?
(cpu) -> # snmpget pix .1.3.6.1.4.1.9.9.109.1.1.1.1.5.1
snmpget: Agent reported error with variable #1.
.iso.org.dod.internet.private.enterprises.cisco.ciscoMgmt.ciscoProcessMIB.ciscoProcessMIBObjects.cpmCPU.cpmCPUTotalTable.
cpmCPUTotalEntry.cpmCPUTotal5min.1: SNMP: Variable does not exist or access is denied.
(conns) -> # snmpget pix .1.3.6.1.4.1.9.9.147.1.2.2.2.1.5.40.6
cisco.ciscoMgmt.147.1.2.2.2.1.5.40.6 : Unsigned32: 205
Tomasz Ostaszewski
09-18-2003 06:26 AM
You figured it out - that capability only came about a certain version of PIX OS - might have been 6.1, more likely 6.2 - I distinctly recall that they added that feature, but forget which specific PIX OS rev had it first
09-22-2003 08:13 AM
Starting in version 6.2, the Cisco Process MIB is supported, as documented here:
