cpu utilization Cisco 6400
What is the maximum cpu utilization recommended by Cisco for 6400?
1 REPLY
Re: cpu utilization Cisco 6400
Normally for all the platforms, the CPU utilization should not be over 50% in average.
If it reaches about 70% in average, then we need break down using "show process cpu" and make sure what is the cause for the high CPU utilization.
If it reaches about 80% to 90% in average, then it will be a problem.
Either a BUG or need to swap to a new powerful platforms.
I belive it will be same to 6400 routers as well.
110
