Community Member
Create and deploy a custom ids signature
I know how to write a snort signature, and it's very easy to deploy that signature. But I am not sure if I can do the same thing to cisco ids, I means easy customizing signature, and quick signature deployment.
1 ACCEPTED SOLUTION
Re: Create and deploy a custom ids signature
The easiest scenario is to use the new Custom Signature Wizard in the latest 4.1 versions of the sensor:
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids10/idmiev/swchap3.htm#31623
If you are using IDS MC for configuration, then I recommend using the Signature Wizard to create the signature on one sensor, then using the created fields you can add that signature into IDS MC for deployment onto multiple sensors.
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/vpnman/vms_2_1/idsmc11/ug/ch05.htm#520329
Step 5 for adding signatures
Silver
You can create string based signiture.
"sensor signiture menu"-------> " active signiture template"---------> " signitures menu"------------->"String signiture menu"
----->'Add strign name or number"-------> Specify a port and "To or From" depending on requirement.
------>Enabel and IP LOg or Block.
Community Member
Where did you perform the steps, ciscoworks?
201
