create two tunnel
HI,
I am using cisco 1751 to connect to my concentrator overseas. How can I create two tunnel to connect to the concentrator ?
Pls advice
Re: create two tunnel
Why do you want to create two tunnels? The router and concentrator will build a separate tunnel for each traffic pattern (each line in your crypto access-list), but you can't build two tunnels for the same traffic. I'm not sure what you're trying to accomplish here, you wouldn't get any extra bandwidth or anything like that. Can you explain further?
The reason is I need to setup a mailserver and replicate to the other mail server on the other end. So I need to create two different subnet so that if the replication fail, it will not affect the other subnet.
Pls advice if you have better solution for doing this.
86
