I have a PIX 525 6.3. I have not set up VPN connections before. I want to set up VPN connections for some remote users that are using Cisco VPN Client 4.8. I have tried to use the Cisco Guide but it is just so much to try and absorb at 1 time. I did use the VPN Wizard. For the VPN clients to connect and be able to access our private network ...I need to provide them with group name ...password...and the IP. Is this the Public IP I have assigned to my outside interface? I wish I could find a more user friendly guide to setting up VPN. I want to get SSL VPN working as well but I just need to get past the current VPN learning curve. I understand Easy VPN setup to a point becasue I enabled it but I did something wrong because inside users could no longer access the internet and a Cisco VPN web page appeared so I removed the Easy VPN setup. Here is my current config that I will test tonight
global (outside) 1 199.x.x.x
nat (outside) 0 access-list outside_nat0_inbound outside
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dymap 10 set transform-set myset
crypto dynamic-map dynmap 10 set transform-set myset
crypto dynamic-map dynmap 30 set transform-set myset
crypto dynamic-map inside_dyn_map 20 match address inside_cryptomap_dyn_20
crypto dynamic-map inside_dyn_map 20 set peer 199.x.x.x
crypto dynamic-map inside_dyn_map 20 set transform-set ESP-DES-MD5
crypto map mymap 65535 ipsec-isakmp dynamic dynmap
crypto map inside_map 65535 ipsec-isakmp dynamic inside_dyn_map
crypto map inside_map interface inside
isakmp enable outside
isakmp key ******** address 199.x.x.x netmask 255.255.255.255 no-xauth no-
nfig-mode
isakmp identity address
isakmp nat-traversal 20
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup HRTVPN address-pool HRTVPNSS
vpngroup HRTVPN dns-server 192.168.17.32 192.168.17.60
vpngroup HRTVPN wins-server 192.168.17.60
vpngroup HRTVPN default-domain hrtransit.org
vpngroup HRTVPN idle-time 1800
vpngroup HRTVPN password ********
vpngroup VPNHRT1 address-pool VPNHRT1
vpngroup VPNHRT1 dns-server 192.168.17.32 192.168.17.60
vpngroup VPNHRT1 wins-server 192.168.17.60
vpngroup VPNHRT1 default-domain hrtransit.org
vpngroup VPNHRT1 idle-time 1800
vpngroup VPNHRT1 password ********
