cross interface communication
current config:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 vpn01 security10
nameif ethernet3 surveys01 security15
nameif ethernet4 global01 security75
nameif ethernet5 available01 security25
i want to know what i need to do to allow communication between all of these interfaces. all servers on all interfaces need to be able to access every server on global01, inside, and surveys01 interfaces. I have an internal DNS server that all of the servers are commonly connected to via a switch and NIC3 on each server. So they all can access a common zone file. I know I had major problems in the past and the alias command just didn't cut it.
THanks well in advance,
1 REPLY
Re: cross interface communication
in additon i set up static translations for all interfaces and the outside such as
static (inside,outside) internal external mask
static(vpn01,outside) internal external mask
etc.
so far i've only done static translations from each interface to the outside interface.....
99
