CRYPTO-4-RECVD_PKT_INV_SPI:
I have cisco 2612 router configure to accept VPN Client connection. This connection are accepted via eth 0 interface. The crypto configuration and the crypto map use are the following:
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp keepalive 10 5
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set prueba esp-3des esp-sha-hmac
crypto ipsec transform-set prueba1 esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set prueba
match address 160
reverse-route
crypto dynamic-map BPS 10
set transform-set prueba1
match address 150
reverse-route
crypto map empleado client authentication list user_authen
crypto map empleado isakmp authorization list user_author
crypto map empleado client configuration address respond
crypto map empleado 10 ipsec-isakmp dynamic dynmap
The problem is that the connection are disconnected randomly. The message send to the syslogs is the following: CRYPTO-4-RECVD_PKT_INV_SPI:
How I can resolve this problem?
Thanks in advance.
Re: CRYPTO-4-RECVD_PKT_INV_SPI:
What version of client and router are you running? How random is this? Is the tunnel up in use and in the middle of say sending traffic it drops? Or are they sitting idle? Are you running a routing protocol on your router? That message indicates that the tunnel on one side has basically dropped but the other side thinks its still up so it continues to send traffic.
Kurtis
The router version is: Version 12.2(11)T.
The VPN client version are: 3.6.2 and 3.5.1.
How random is this?
The frequency is randomly, in some case it is 4 or 5 times a day.
Yes
Yes, generally occur this case.
No
The remote user receive the message "peer no longer responding".
Thanks.
Try removing the reverse-route from the router, if your not running a routing protocol, it wont be needed and I remember there being a problem with that if you have a accelerator card. You might wanna upgrade the code as well to 12.2.11T2.
Kurtis Durrett
I remove the reverse-route. I wait for the syslog for new message.
I have a problem with card accelerator. I can't use it. When I enable (crypto engine accelerator) this card the performace go down. I think that is a routing problem.
Do you know this bug?
The version 12.11T2 resolve this bug?
Do you know where I can subscribe a e-mail list for receive new cisco advisor?
Thanks in advance.
Im not sure of the bug id that was assigned or if it was filed with this in 12.2.11T or if 12.2.11T2 will fix it. Open a case with TAC to pursue this on the bug and which code, if any, will fix it. You could always try 12.2.11T2 and see if it fixes your problem or check the release notes for that release to see
if its listed as a known bug and/or fixed. I didnt find it myself, but have a look for your self: http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cavs/122tcavs.htm
Kurtis Durrett
465
