CRYPTO-4-RECVD_PKT_NOT_IPSEC
I configured Dual Hub IPSec with preshared keys over GRE Tunnels.
(1-st tunnel to Hub A, 2-nd tunnel to Hub B)
Tunnel to Hub A is up & down to Hub B. How can I fix it?
Follwing messages in log on spoke routers
*Mar 3 20:42:03.631: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC p
acket. (ip) vrf/dest_addr= /172.16.0.26, src_addr= 172.16.0.2, prot= 47
Hub A
Crypto Map "ua" 10 ipsec-isakmp
Peer = 172.16.0.26
Extended IP access list 150
access-list 150 permit gre host 172.16.0.50 host 172.16.0.26
Current peer: 172.16.0.58
Security association lifetime: 4608000 kilobytes/3600 seconds
PFS (Y/N): N
Transform sets={ des, }
Interfaces using crypto map ua:
Serial0/0.200
Hub B
Peer = 172.16.0.26
access-list 150 permit gre host 172.16.0.2 host 172.16.0.26
access-list 150 permit gre host 172.16.0.2 host 172.16.0.18
Serial0/0.200
sh crypto isakmp sa
172.16.0.2 172.16.0.26 QM_IDLE 2 0
sh crypto engine connections active
2 Fa0/0.300 172.16.0.2 set HMAC_MD5+DES_56_CB 0 0
Spoke
Crypto Map "kiev" 10 ipsec-isakmp
Peer = 172.16.0.50
Peer = 172.16.0.2
Extended IP access list 115
access-list 115 permit gre host 172.16.0.26 host 172.16.0.50
access-list 115 permit gre host 172.16.0.26 host 172.16.0.2
Current peer: 172.16.0.50
PFS (Y/N): N
Transform sets={
des,
Interfaces using crypto map kiev:
FastEthernet0
Re: CRYPTO-4-RECVD_PKT_NOT_IPSEC
Going by your output you have the following configured on th espoke:
crypto map kiev 10 ipsec-isakmp
   set peer 172.16.0.50
   set peer 172.16.0.2
   set trans
   match address 115
By defining only one instance of the crypto map and putting two "set peer" statements under it you're saying that you want the second peer to act only as a backup to the first peer in case it is down, which is what you're seeing.
If you actually want both to be up at once for redundancy and routing purposes then you need to define two instances of the crypto map and separate them out as such:
   set trans
   match address 115
crypto map kiev 20 ipsec-isakmp
   set peer 172.16.0.2
   set trans
   match address 120
access-list 120 permit gre host 172.16.0.26 host 172.16.0.2
Note there are two instances of the same crypto map (instance 10 and 20) pointing to two different peers with two different access-lists. Both should come up now if your routing process includes the tunnel interfaces.
Thanks for your answer. You are right & now i'm implementing EIGRP in my network & I need
both tunnels to be active in same time.
Do i need to change crypto map on Hub B?
I changed config on the Spoke router:
Peer = 172.16.0.50
access-list 115 permit gre host 172.16.0.10 host 172.16.0.50
PFS (Y/N): N
Transform sets={
des,
Crypto Map "kiev" 20 ipsec-isakmp
Peer = 172.16.0.2
Extended IP access list 116
access-list 116 permit gre host 172.16.0.10 host 172.16.0.2
Current peer: 172.16.0.2
PFS (Y/N): N
Transform sets={
des,
FastEthernet0
10 permit gre host 172.16.0.10 host 172.16.0.50 (2659 matches)
10 permit gre host 172.16.0.10 host 172.16.0.2 (138 matches)
but I still cant ping tunnel ip of the Hub B.
Here is crypto map from Hub B.
crypto Map "ua" 10 ipsec-isakmp
Peer = 172.16.0.50
Peer = 172.16.0.10
Peer = 172.16.0.26
Peer = 172.16.0.54
Peer = 172.16.0.58
access-list 150 permit gre host 172.16.0.2 host 172.16.0.50
access-list 150 permit gre host 172.16.0.2 host 172.16.0.10
access-list 150 permit gre host 172.16.0.2 host 172.16.0.54
access-list 150 permit gre host 172.16.0.2 host 172.16.0.58
Current peer: 172.16.0.10
PFS (Y/N): N
FastEthernet0/0.300
297
