Crypto engine counters
manyushinv
i have 2801 cisco router with onboard crypto engine. I have misunderstand some counters in crypto engine statistics
Onboard crypto engine:
ds: 0x64AED5F8 idb:0x64AEC538
Statistics for Virtual Private Network (VPN) Module:
244045 packets in 244045 packets out
394 paks/sec in 394 paks/sec out
2487 Kbits/sec in 2560 Kbits/sec out
99098 packets decrypted 144947 packets encrypted
packet overruns: 0 output packets dropped: 0
tx_hi_drops: 0 fw_failure: 0
invalid_sa: 0 invalid_flow: 0
null_ip_error: 0 pad_size_error: 0 out_bound_dh_acc: 0
esp_auth_fail: 0 ah_auth_failure: 0 crypto_pad_error: 0
ah_prot_absent: 0 ah_seq_failure: 0 ah_spi_failure: 0
esp_prot_absent:0 esp_seq_fail: 0 esp_spi_failure: 0
obound_sa_acc: 0 invalid_sa: 0 out_bound_sa_flow: 0
invalid_dh: 0 bad_keygroup: 0 out_of_memory: 0
no_sh_secret: 0 no_skeys: 0 invalid_cmd: 0
pak_too_big: 0
tx_lo_queue_size_max 0 cmd_unimplemented: 0
flow_cfg_mismatch 0 flow_ip_add_mismatch: 0
unknown_protocol 0 bad_particle_align: 0
619 seconds since last clear of counters
Interrupts: Notify = 180299
What "Interrupts: Notify" mean? on another routers i have zero.
smahbub
Level 6
Level 6
It just shows the router cpu sent interrupt to the crypto cpu to process some more crypto packets to be processed
