01-07-2008 10:18 PM - edited 03-09-2019 07:47 PM
hello,
i have routers terminating vpn on both sides with the loopback ip address as peers.
should i apply the crypto on the loopback interface or on the wan interface?
Thanks.
01-08-2008 08:42 AM
You apply the crypto map on the wan interface.
Dont forget to identify the loopback interface as the source in you crypto-map
crypto map mapname local-address loopback 0
Please rate helpful post
01-11-2008 12:37 AM
Any sample config please.
01-09-2008 09:22 AM
After following the information posted by dominic.caron, make sure that the VPN Devices have routing information for the loopback address. That is IP Connectivity.
Arul
