CSA 5.1 and Spotlight from Quest Software
I am having an issue getting Spotlight to connect to any Exchange servers (This server is an OMA server) to monitor them if the CSAgent is installed. Has anyone run across this issue before? I thought maybe it was one of the rules, but I put the agent into learning and Test mode and it didn't help. I am still learning the CSA Software, so any suggestions or help would be appreciated.
Perez
Silver
Re: CSA 5.1 and Spotlight from Quest Software
Do you get any errors ?
Not really, once the Agent is installed and I try to connect from the monitoring server with Spotlight, spotlight display's the message:
Failed to connect to
No real error messages or id numbers, just that it can not connect.
Now if I un-install the agent, then I can connect with Spotlight again.
90
