CSA advanced Cmd Shell policy
I'm trying to design a Command Shell policy meeting specific criteria. I don't want to just log each time cmd.exe is used. Instead, I want to log each time cmd.exe executes a command that either affects another file (change/delete), or displays important system information (like ipconfig, nbtstat, arp, set, net view, route print, ping, tracert, etc.)
Sound like something I could do?
Blue
Re: CSA advanced Cmd Shell policy
Create a rule that logs when the command shell accesses files of any type to write and reads any of the exe's you are concerned with.
That's exactly what I did - glad I was on the right track. ;) But any suggestions on the 2nd half?
Blue
Yes, the second rule should report when a command shell executes a read on any of those files you are concerned with.
Tom S
168
