CSA Agent Kits upgrade
Hi all
I have a question. I have already made the migration from version 5.1 to 6.0, I would like to know how to upgrade Agent Kits? I need uninstall Agent Kit version 5.1 and download and install Agent Kit version 6.0 or there is a way for the migration Agent Kits?
Blue
Re: CSA Agent Kits upgrade
You can schedule an upgrade for hosts under Systems>Software Updates>Scheduled Software Updates.
There is no need to uninstall first.
Tom
thx for help :)
may I ask one more question?
when migration is done, the host are not attach to the group which i create. How I fix this? or I need attach again?
Blue
You can create an agent kit that automatically attaches them to the group you want them in and use that for the software upgrade or just move them manually.
Tom
thanks a lot :)
113
