CSA Data Theft Hole?
I followed the guide to test the data theft protection policy and it worked just fine on everything except attaching the file within the protected directory to an email generated by Outlook Web Access.
Is this a known hole or do I need to specify something else?
1 ACCEPTED SOLUTION
Blue
Re: CSA Data Theft Hole?
Were you able to read the file?
I tried it and it sent a blank attachment.
Tom
Blue
Tom
I did not. Let me find out.
John
It worked, however it didn't until after I went into the cloned data theft module and identified that one of the associated rules was not enabled. It was rule ID 153 - network application access.
Blue
Yep, it comes disabled by default. Not sure why though...
Hey, cool guide! Thanks for the link.
Maybe Cisco will include it on the CSA page:
http://www.cisco.com/en/US/products/sw/secursw/ps5057/index.html
Anyone listening?
Tom
Can you post where that guide is?
Thanks.
It can be found here:
http://www.cisco.com/application/pdf/en/us/guest/products/ps5057/c1031/cdccont_0900aecd804f00d6.pdf
I found it to be one of the best pieces of Cisco
help I've seen them put out.
Silver
This is excellent! Do you know if anymore exist, specifically for MARS or NAC?
Thanks!
113
