Community Member
CSA Error
I have been attempting to install the new version of CSA on my Call Manager Lab Server. It comes up with the error:
This self extracting Zip file is part of a multi disk zip file. Please insert the last disk of the set.
I am using VNC to install this software and no current version of CSA is installed.
Blue
Re: CSA Error
Are you installing the agent or the entire MC? That messages sounds like you are running setup.exe from the first .zip file of the 4 part VMS 2.3 install set.
Just a guess....
Community Member
Re: CSA Error
Have proceed past this issue as it was a bad download from cisco.
185
