CSA groups in Test Mode
Let's say that I have a host in 3 groups - <All Windows>, TestGroup, OtherGrp.
By default my Host is in <All Windows>, I can't remove it. I don't have any policies assigned to <All Windows>. The other two groups do have policies.
So now my Host is running rules from the 2 other groups. If I put <All Windows> into Test Mode, what happens? My Host will show that its in Test Mode, because its inheriting it from <All Windows>.
Is the Agent completely in Test Mode? Does Test Mode only apply to the group it isn't enabled on? So if my two other groups aren't in test mode, are the rules still working normally, or is <All Windows> overwriting that setting?
1 ACCEPTED SOLUTION
Blue
Re: CSA groups in Test Mode
If a host is in a group that is in test mode, all rules that apply to the host are in test mode.
A host can have rules in test mode and still have other rules in protect mode.
Tom S
Blue
Tom S
Okay, thanks. I just found that in the book Cisco Security Agent, p. 345, as well.
So if you put into test mode, you've put ALL your Hosts and ALL of the Rules into test mode.
You can't copy the all windows.
But polices and rules are attached.
I recommend making a new group, make copies of the policies attached and attach them to your new group.
This way you can edit them without affecting the original.
105
