csa management
how is csa deployed to numerous workstations? do i require something more aside from the csa agent?
thanks
Blue
Re: csa management
It requires the CiscoWorks Management Center for Cisco Security Agents.
Here is a link:
http://www.cisco.com/en/US/products/sw/cscowork/ps5212/index.html
Tom S
Re: csa management
so is this the same management console that the command and control of the ssm module on the asa requires?
thanks
Blue
Re: csa management
This is the CiscoWorks VPN/Security Management software. I don't believe it manages ASAs.
Tom S
Silver
Re: csa management
You wouldn't want to manage both the CSA agents and ASAs even if that were possible. VMS rides on top of CiscoWorks and a is very slow product that Cisco is promising to overhaul.
At the present time your best bet from my experience is to keep the CSA Management on a separate box. If you require a VMS platform to manage Firewalls and VPN devices then buy another box. This is expensive but the amount of your time you will save will more than make up for it.
Re: csa management
IS THIS VMS the same module needed for the command and control port of the ssm module in the asa?
106
