CSA MC 6.0
we are planning to deploy CSA-MC6.0 on our network and would like to activate the following security policies.
-stop coping data from a system to external devices (CD,USB etc)
-stop downloing music/multimedia files
-stop streaming vedio (ie. youtube)
-stop chat programs
-stop installing any .exe files
Curretly I crated a test group and put some rule modules which are identified to fulfil the above requirement, unfortunately none of the rules didnt work with above requirement.
Can any one sugesst me what are the appropriate rule/rule modules to fulfil the above requirement on CSA MC 6.0
tks
Re: CSA MC 6.0
sorry here are my group (TestGroup1) and policies/rule and rule modules
Re: CSA MC 6.0
First of all, check that the agent has actually dowloaded the relevant rules. You can see this in the Agent Panel under status. Once you've verified that the new rules have downloaded, test them by, for example, trying to install something and check the MC for logs.
Blue
Re: CSA MC 6.0
I don't believe you've stopped all .exe's from installing, just those invoked by Mass software deployment apps.
I also don't know if you are preventing writing to USB devices (it's hard to tell from your screenshots).
You are probably going to be better off not trying to clone a bunch of rules that 'might' stop what you want to stop and just create some specifically targeted rules.
That way if it stops it, you can loosen the restrictions as needed until it works the way you want.
A few specific File Access and Application Control rules may be what you need.
Streaming media may be a bit harder and is probably better done with web filtering.
It is possible, but difficult to maintain.
Tom
Re: CSA MC 6.0
Thanks Tom for your response. I have stop all of rules on Mass Software deployment rule modules but it didnt work out.
Prevent writing to USB devices rule I used worked only writing from system to any USB but also need visa verse.
Could you please advise me what are the appropriate rule/rule modules to fulfil my those security policies.
thanks
120
