CSA MC block website
We have CSA MC v5.2 and CSA agent on all PC, is there any way to define policy to block certain website, like youtube or facebook etc. while blocking, can this be done by name instead of IP address?
thanks
Silver
Re: CSA MC block website
Hi Guy,
You should consider a proxy or a product like Websense if you want to block certain websites.
Let CSA concentrate on what it does best: protecting your assets from worms and viruses. It does a magnificent job of correlating the behavior of your end systems. Your host-based intrusion protection systems like CSA should only be tasked to monitor things like file and memory access, process behavior, and access to shared libraries.
Block websites at the perimeter, or as close to the perimeter as possible and don't overload your workstations and servers with processes better performed by other devices.
Hope this helps.
Paul
200% agree on your point.
however, you did not answer my question.
thanks
Data sets are variables that you can use as data access control rules. These sets are sets of strings that you can group together. Their only purpose is to be matched against the Uniform Resource Identifier (URI) in HTTP requests
Choose Configuration > Variables > Data Sets.
then you can make the data set with URI u want to match with a rule that applied to all http requests from ur inside to any as outside
if u have ASA/PX do it there
if u dont know how tell me i can help u
good luck
please, Rate if helpful
Please give more detailed steps, I did not see how to make the data set with URL
thanks
the mentioned above not URL it is uri which is part from a URL
like www.wesite1.com/infro/books
so the /info/books/ csan be considered as a uri
u just need to know how to make a data set
which should be like the above example
try to make it like
*.youtube.com/
*.youtube/.com
not sure but try like the above ways
dont forget on ur rule to make the right rource and destination IPs
good luck mate
Rate if helpful
128
